Voici une photo avec le détail en Anglais des réglages du handler de chez Slot-it
Features
1 - contactless trigger position readout
2 - adjustable braking (Brake knob), sensitivity (Min speed knob) and
'Antispin' (Power trim knob)
3 - the fourth knob has two working modes:
a - max speed: it sets the max speed from 100% down to 40% of the max.
Great if you have children. Ghost car / motor run-in mode.
b - set curve: continuosly variable middle point of power curve (coupled
with the adjustable sensitivity, what it means is that you have two
adjustable points in the power curve and can tune the response to your
needs)
4 - datalogging and telemetry interface (requires additional external
box available later on)
5 - interchangeable I/O module for compatibility with: standard
analogue, SSD, N-dig (and possibly others)
6 - pricing: won't break your bank account.
Availabilty: what you see here is a picture of the 'Prototype1'.
'Prototype2' mods are already under way and Prototype2 will be final, so
we expect it to hit the streets in the second quarter of 2007.
