Hi all
We are releasing, as beta version, the new 'Chrono' RMS software
OXIGEN_CHRONO v. 0.0.99a
http://www.slot.it/Download/oXigen/Softwar...taller_099a.zip
It should be complemented with the new dongle 2.05 and controller 2.12 versions that can be found either inside
http://www.slot.it/Download/oXigen/Firmwar...ware-latest.zip (only latest versions)
or
http://www.slot.it/Download/oXigen/Firmware/firmware.zip (all versions including old ones)
What's new:
as I'm rushing towards a plane that's not going to wait for me, I may forget a few points but I'll be more precise on Monday
1 - introduces all that's necessary for automated track call, which is not enabled yet - but everything we need is there
2 - minimum lap time filter: set a minimum lap time and anything below will be filtered out. What does this mean exactly? If you expect a lap time of say 10", set a 9" minimum lap time. Let's say your car crosses the finish line and them after 4", for whatever reason you pick up a stray lap signal. This will be ignored, lap time will not be reset, and your car will count laps only when it reaches the finish line.
3 - fixes a bug which could upset lap counting if a 2nd controller was switched on on the same frequency of a running car
4 - RMS displays on screen GAP between cars, as well as the following information: car reset (strikethrough car#), car dropped packet (italics car#), car off track in pitlane (pink background). Don't remember if we signal the battery low condition, too. If not it will be in 0.99b...
5 - core rewrite of the RMS sw - it should be faster and more reliable. Of course it may be buggy, too, hence 0.99a.
6 - redesigned screen layout to fit display size when an external monitor is attached to the PC
For all of this to work you need dongle 2.05 (new), controller 2.12 (new), car 2.08 (already previously released)
Please also refer to my post for further explanation:
http://www.slotforum.com/forums/index.php?...st&p=782802
Regards
Maurizio
