Imprimer les messages du sujet "Guardrail alternative"
Posté le 24/11/2014 à 21h59 par Rainer Selzer
First I have bought a 3 - wire ribbon cable and a round aluminum tubing from the hardware store. The aluminum tube I cut into 3.5 cm long items. Then I painted the items and the ribbon cable gray. Now I screwed 6 cm long screws through the plywood and chipboard. About this the cutted aluminium tubings were placed and glued with super glue. Final I glued the ribbon cable to the aluminium tubings and fixed with clothes pins. Alternative you can attach the cable to the aluminum tube pieces with small screws. Maybe someone wants to try it.
Regards
Rainer
Posté le 24/11/2014 à 22h12 par simamine
Well done, good idea and good job!
Congratulations!
Posté le 25/11/2014 à 05h42 par Brifou
Même en anglais, c'est du joint, dit joint P, pour calfeutrer les portes et fenêtres, (casto),
après on met les potos qu'on veut,
j'avais déja signalé, et mis des photos,
Rangé des voitures
