Imprimer les messages du sujet "MISE A JOUR OXYGEN"
Posté le 06/05/2013 à 17h43 par fs83
Hi all
We are releasing, as beta version, the new 'Chrono' RMS software
OXIGEN_CHRONO v. 0.0.99a
http://www.slot.it/Download/oXigen/Softwar...taller_099a.zip
It should be complemented with the new dongle 2.05 and controller 2.12 versions that can be found either inside
http://www.slot.it/Download/oXigen/Firmwar...ware-latest.zip (only latest versions)
or
http://www.slot.it/Download/oXigen/Firmware/firmware.zip (all versions including old ones)
What's new:
as I'm rushing towards a plane that's not going to wait for me, I may forget a few points but I'll be more precise on Monday
1 - introduces all that's necessary for automated track call, which is not enabled yet - but everything we need is there
2 - minimum lap time filter: set a minimum lap time and anything below will be filtered out. What does this mean exactly? If you expect a lap time of say 10", set a 9" minimum lap time. Let's say your car crosses the finish line and them after 4", for whatever reason you pick up a stray lap signal. This will be ignored, lap time will not be reset, and your car will count laps only when it reaches the finish line.
3 - fixes a bug which could upset lap counting if a 2nd controller was switched on on the same frequency of a running car
4 - RMS displays on screen GAP between cars, as well as the following information: car reset (strikethrough car#), car dropped packet (italics car#), car off track in pitlane (pink background). Don't remember if we signal the battery low condition, too. If not it will be in 0.99b...
5 - core rewrite of the RMS sw - it should be faster and more reliable. Of course it may be buggy, too, hence 0.99a.
6 - redesigned screen layout to fit display size when an external monitor is attached to the PC
For all of this to work you need dongle 2.05 (new), controller 2.12 (new), car 2.08 (already previously released)
Please also refer to my post for further explanation:
http://www.slotforum.com/forums/index.php?...st&p=782802
Regards
Maurizio
sp-collectable.com
Posté le 06/05/2013 à 17h44 par fs83
Salut à tous
Nous publions, en version beta, le logiciel RMS la nouvelle 'Chrono'
V OXIGEN_CHRONO. 0.0.99a
Il devrait être complété par les nouveaux 2:05 dongle et 02.12 versions contrôleur peut être trouvé à l'intérieur
http://www.slot.it/Download/oXigen/Firmwar...ware-latest.zip (dernières versions uniquement)
ou
http://www.slot.it/Download/oXigen/Firmware/firmware.zip (toutes versions, y compris les plus anciens)
Quoi de neuf:
que je me dépêche vers un plan qui ne va pas à attendre pour moi, je peux oublier quelques points, mais je serai plus précis lundi
1 - Présente tout ce qui est nécessaire pour l'appel de la piste automatisé, qui n'est pas encore activée - mais tout ce qu'il faut est là
2 - Filtre minimum de temps au tour: définir un chrono minimum et rien en dessous seront filtrés. Qu'est-ce que cela signifie exactement? Si vous prévoyez un chrono de dire 10 "réglé à 9" chrono minimum. Disons que votre voiture franchit la ligne d'arrivée et les après 4 ", pour une raison quelconque vous décrochez un signal de tour parasite. Ce sera ignorée, temps au tour ne sera pas remis à zéro, et votre voiture va compter les tours seulement quand il atteint la ligne d'arrivée .
3 - qui corrige des bugs pourrait bouleverser tour de comptage si un 2ème contrôleur a été allumé sur la même fréquence d'une voiture en marche
4 - RMS affiche sur les BPA de l'écran entre les voitures, ainsi que les informations suivantes: voiture de réinitialisation (voiture # barré), la voiture a chuté paquet (# italique voiture), voiture hors piste dans la pitlane (fond rose). Ne me souviens pas si nous signalons le faible état ​​de la batterie, aussi. Sinon, il sera en 0.99b ...
5 - core réécriture du RMS sw - il devrait être plus rapide et plus fiable. Bien sûr, il peut être bogué, aussi, d'où la volonté 0.99A.
6 - redessiné écran aménagement taille de l'écran pour s'adapter Lorsqu'un moniteur externe est connecté au PC
Pour tout cela fonctionne, vous devez dongle 05.02 (nouveau), contrôleur 2.12 (nouveau), voiture 8.2 (déjà publié précédemment)
Aussi s'il vous plaît se référer à mon post pour plus d'explications:
Cordialement
Maurizio
sp-collectable.com
Posté le 06/05/2013 à 18h32 par gaets57
cool j'ai hâte de tester ça
Posté le 18/05/2013 à 22h34 par Maurizio
Disponible logiciel RMS RMS 0.99b. Tous comme 0.99a mais logiciel bien plus vite.
Posté le 18/05/2013 à 23h08 par fs83
Maurizio :peux tu faire passer a PCLAP pour mettre a jour son logiciel car il y a des problèmes de pertes d'information avec son logiciel .
tout va bien avec le logiciel slot it .
sp-collectable.com
Posté le 19/05/2013 à 10h48 par Maurizio
Je l'ai déjà dit a Cristian qui est en charge, mais il n'a encore pas mis à la disposition le fichier du protocole ... Je le répète demain
Posté le 19/05/2013 à 14h01 par fs83
c'est surtout pour les utilisateurs de PCLAP que je dis ça car avec le logiciel slot it s'est bon
donc les utilisateurs de PCLAP patientez un peu pour la mise a jour.
sp-collectable.com
Posté le 21/05/2013 à 09h26 par Maurizio
Fait. Il faudra quelques jours pour Guy je croix.
Posté le 11/06/2013 à 16h58 par Maurizio
Bonjour.
Le nouveau mise au jour oXigen est disponible:
Dernière version du logiciel dongle / poignée / voiture: 2.05, 2.14, 2.09
http://www.slot.it/Download/oXigen/Firmware/firmware-latest.zip
Quoi de neuf:
1 - sélection du mode de travail: oXigen ou Hornby SSD ou Carrera D132 compatible, à partir de votre contrôleur. Reprogrammez ID et système de la poignée, pas besoin de reprogrammer la voiture du bootloader!
2 - 'track call' (arrêter la course et redémarrer) automatique ou manuel. Il faut avoir la dernière version de PC Lap Counter, de moment. En suite, aussi avec notre logiciel.
S'il vous plaît lire le manuel (anglais)
http://www.slot.it/Download/oXigen/Manuals/BaseDescriptionO2.en.pdf
Par ailleurs, la nouvelle version de RMS Crono 0.99b fonctionne très bien dans les mains de nos clients.
The new firmware is available:
Latest dongle/controller/car firmware: 2.05, 2.14, 2.09
What's new:
1 - selecting working mode: oXigen, Hornby SSD or Carrera D132 compatible, from your controller. Reprogram ID AND system from the controller, no need to reprogram the car from the bootloader!
2 - track call support. Needs latest version of PC Lap Counter.
By the way, the new RMS Crono version 0.99b works very well in the hands of our customers.
Please download the updated manual
Cordialement / Regards
Maurizio
Posté le 10/09/2013 à 18h36 par baba
Bonsoir,
Pourriez-vous m'expliquer comment effectuer les mise à jour
des puces, des poignées et de la dongle.
Je vous remercie par avance.
Posté le 11/09/2013 à 19h15 par fs83
Baba : tel a CHRIS de SP
sp-collectable.com
Posté le 23/04/2014 à 11h32 par fs83
sp-collectable.com
Posté le 23/04/2014 à 12h33 par fs83
oXigen news:
1 - new bootloader 0.99 beta 1 software is finally available. More stable, and with 'clone device' feature
2 - controller firmware 2.18 is available. This is a recommended update for all customers using earlier versions
Download it from Slot.it's oXigen download page
http://www.slot.it/INGLESE/Download_Oxigen.html
sp-collectable.com
