Imprimer les messages du sujet "Oxigen et SSD power base ?"
Posté le 24/04/2012 à 11h31 par m41g
Je m'interroge sur oxigen et la powerbase ssd ?
"Q: Can I use O2 cars with an SSD power base?
A: Hornby SSD lane changers work well with oXigen cars, and with some ingenuity you can use
Hornby's power base as a lap counting/finish line for oXigen cars. The trick is to power the rails
separately to a fixed voltage and use the Power Base as a lap counter only, for up to 6 cars: oXigen
cars are not compatible with the rail-transmitted SSD protocol, but the O2 LED protocols used for
lap counting and lane changing are compatible with SSD devices."*
Parle t'on de la powerbase c7042?
merci de vos lumieres
m41g
*extrait de la faq oxigen slot it
http://www.hotslots132.com/oXigen_FAQ.pdf
